2 Litre Zetec into MK3 Escort
Hi, I've already picked out a lot of info off this site for the conversion, and have sorted usual oil and water pump, sump, clutch etc, and have the engine and box bolted into the car. What I have received conflicting info about though, is whether to use the CVH alternator and starter motor, or the ones off the Zetec. All advice appreciated, thanks.
Use the CVH starter (assuming BC box) and alternator with the zetec pulley & belt, think there's two sorts of CVH alternator but only one will take the zetec pully
edit you might need a different belt, mines a 6pk923
You might need a bracket to lower the alternator bracket further down the engine, I did on a mk4, should be similar.
Edit to add that's if your using a Blacktop zetec.
Its a silver top, have changed water pump to turn the correct direction with the PAS pump removed. Next problem will be the ECU, I have a PATS one, but no key.
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
