Puma radio interference when ignition on or engine running.
Ford Puma 1.6 2001
The original Ford 6000 CD player wouldn't tune 99% of the time and as they are known to go wrong I replaced it with a new Panasonic head unit and used an Autoleads ISO wiring adaptor harness.
Problem is this...
Turn key to position 1: Radio works faultless
Turn key to position 2 or when engine running: Radio tunes fine but has interference, almost like a rhythmic crackle every second or so.
What could be causing this? I've seen you can get an inline noises suppressor filter for the power wire. Is this worth doing?
I have tried routing the wires a bit better, away from the aerial lead etc but problem persists.
Please help as it's driving me nuts!!
Problem is this...
JoeyBoyden
04-01-2024 02:36 PM
Sheepdisease
30-08-2015 09:11 PM
Ben26
27-08-2015 08:56 PM
