Please help codeing injectors
I have just bought a 2003 mondeo tdci 130, it requires the injectors codeing, I bought an F Super with formidable v2.03 and I also bought an ELM327 with Forscan, I have tried to use both and the only thing I have been able to do is read and clear dtc codes and code number 1 injector, the codes I put into the other 3 don't seem to save only number 1, even though it says programming successful at the end, it's running really lumpy and I'm hopeing once injectors are coded properly it will be fine, any help or advice would be great on this.
Thank You
Dan.
Thank You
Dan.
mk3ste
17-10-2021 10:09 AM
