Sierra Sapphire Cosworth No Compression In 3 Cylinders
Hiya all, my boyfriend has a sierra sapphire cosworth and it has no compression in Cylinders 1, 2, 3, but 4 has 60psi he has had a full head rebuild, brand new inlet valves, also a new headgasket & Also when the cams are removed the compression comes back on all 4 but was weak. As soon they go in its gone again etc please help he doesn't know what else to try!!
Does sound like something's up with what was done with the head if it's only just been refitted.
Best bet as said is speak to whoever did the work and get them to confirm they have lapped the valves in properly when they rebuilt it etc.
Once bought a head that had no compression in one cylinder, the guy gave me a refund and turned out there was a problem with a valve guide that had been replaced.
Quick test when a heads off is turn it upside down and pour petrol or thinners into the combustion chamber, should hold the fluid but if not seating properly will leak out, obviously don't help now its fitted though unless/when it's taken off again.
Jack and the Beanstalk
15-08-2015 04:27 PM
Zoggon
10-08-2015 10:39 AM
