over fueling
over fueling
i have a yb 2wd mk1 escort cossie.
it is over fueling and also high revs if I connect the iscv.
I have checked all voltage and resistance all ok.
it is a l6 ecu standard injectors 3bar map sensor.
any clues anyone
any clues anyone
If you are using the standard injectors, why do you have a 3-bar map sensor?
The standard map-sensor for the L6 is a 2-bar sensor.
Although, if the map-sensor is incorrect it would be under fueling.
Has it ever run correctly? Is the chip in the L6 modified or standard?
