no temperature
Old 26-04-2015, 03:16 PM
graham63
graham63's Avatar
Default no temperature
Temperature gauge on Mondeo 2004 tdci only moves when running it hard, gauge drops back when lifting off throttle, have changed both thermostats, can anyone help
Old 26-04-2015, 03:49 PM
3i Jim
3i Jim's Avatar
Could be the temperature sender playing up.
graham63 (26-04-2015)
Old 26-04-2015, 06:12 PM
cabriolet
cabriolet's Avatar
the obvious does the heater work is this the one with the pipe running under the engine that collapses
Old 26-04-2015, 08:48 PM
graham63
graham63's Avatar
Thanks Cabriolet i will check this pipe, air con does work, doesn't get as warm as it used to
Old 01-05-2015, 09:42 PM
Ecosport
Ecosport's Avatar
Have you checked your coolant level?
Derek Burleigh
16-09-2015 06:27 PM
oilman
18
16-03-2005 03:47 PM
foreigneRS
Technical essay Archives
20-07-2004 11:44 AM
foreigneRS
20-07-2004 11:06 AM
L33 BYT
06-07-2004 09:25 PM
Quick Reply: no temperature
