Tensile strength of prop shaft bolts
Do I need to use anything special in terms of the tensile strength for my prop shaft bolts? If so what spec?
The prop shaft company were great but I was amazed they didn't "up sell" the bolts to go with it???
In fact the cossie world and car world do not do a lot to sell optimal add ons....and this is where the profit is, you could charge £400 for the main item and then bolts for £30 at high profit margin.
Mt and mk do sell bolts but still not as a suggested extra, they are just available if you ask.
Caddyshack (17-04-2015)
Top man! Thank You
A lot of OEM prop bolts will be a fine thread, although not really sure why.
But as Rich says, a good quality 12.9 bolt, nyloc nuts etc Ideally if you can get a smooth shank through the holes too, but some do, some dont
Caddyshack (22-04-2015)
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
