MK1 Focus RS running hot (i think)
HI all
can anyone help
i have a MK1 focus rs running about 370 BHP
it has uprated stat housing (DPC)
lower temp thermostat
uprated radiator (auto specialists)
stakk water temp guage
when it warms up it will be at 80 degrees
but then will go up to 100-110 even though not driven hard
if i put heating on will come back down to 80 deprees
is this right what temp should these car run saftley at
thanks
can anyone help
thanks
I wouldn't worry, mines the same and I've had it since 2004.
They just run on the hot side from what I gather.
You could try some of that wetter water stuff, might help a little, I've heard a few people say it makes a bit of a difference.
Don't worry to much the scan gauge takes its temp from the head so the temps will be slightly higher than normal and they do run hot I had mine 6years and that's the readings I get
kosienutter
31
22-08-2015 09:55 AM
saph in dorset
14-08-2015 10:10 AM
