Please help .. About given up :(
Hi guys ,
I'm in great need of some advice ,
Currently in the middle of an rs2000 engine swap into a mk6 escort
Engine is in , everything mechanically is sound and fits
I'm planning on wiring it up this weekend but I'm struggling to get my head around it
(Even with haynes manual)
When I brought the engine I got:
Engine complete with box
Drive shafts
Hubs / brakes
Subframe
And a box full of wiring looms (presumably from the whole car, not had a proper chance to look)
ecu and ignition barrel transponder (no barrel or keys)
I was told that it was from a mk5 rs
But I'm not sure
( the seller I brought off will not reply)
I've quoted the ecu numbers etc in another thread people have said it's showing it's come out of a MK6 rs2000 with the dreaded PATS system :/
I don't have the key
So now I'm not sure if the engine is out of a mk5 (and they have given me the wrong or a random ecu and loom) or is it out of a mk6 ?
Is there anyway I can tell what the engine is out of ?
I've been going through the ecu plug loom i have been given for continuity and it's near enough the same to a mk5 pin out according to haynes manual
I've also have a separate prepats ecu (1abg) in the garage which I know for sure has come from a mk5 rs from a mate ages ago when he smashed his car round a tree
Will this run on a mk6 rs2000 pats loom ?
Could I just bridge the pats box on the loom and use the prepats ecu?
(Assuming the loom I have got is a match to the pats ecu I was sent and I've not got a load of random stuff all from different cars)
Cliffs
- what's the difference between mk5 and mk6 rs looms?
- if it is a mk6 loom , could I bridge over the PATS and run the non pats ecu?
-did the mk6 rs have external or internal edis ?
(I've got an edis 4 unit and the plug in connector on the ecu loom that came with engine )
Any help would be appreicated as it's making my head hurt now
Thanks
Drive shafts
Hubs / brakes
Subframe
But I'm not sure
Cliffs
Thanks
