2008 1.8 Diesel Focus Estate - Coolant leak found - what's this called?
Old 24-02-2015, 12:16 PM
mouters
mouters's Avatar
Default 2008 1.8 Diesel Focus Estate - Coolant leak found - what's this called?
Hi,
I've found a coolant leak but unsure what the part is called in order to replace. It's the plastic joint - the right one (not left) that connects pipe to middle (round) box. The side you can't see gushes coolant when engine is running. Its in the middle of the joint and not the edges that pipe connects to so I'm sure I need to replace it. I can even put my finger on it to stop the leak.
Here are some pictures.
Any ideas?
Many thanks.
UPDATE - more picutres
other end of pipe into bulkhead
underside shows hole!
Old 24-02-2015, 12:28 PM
RichieST
RichieST's Avatar
Do the hoses go through the bulkhead to the heater matrix?
mouters (24-02-2015)
Old 24-02-2015, 12:41 PM
mouters
mouters's Avatar
Yes I've added some more pictures - even managed to get one of the hole.
Old 24-02-2015, 01:32 PM
mark826
mark826's Avatar
Looks like egr cooler to heater matrix hose (top hose)
mouters (26-02-2015)
Old 24-02-2015, 01:47 PM
mouters
mouters's Avatar
Originally Posted by mark826
Looks like egr cooler to bulkhead hose (top hose)
Thanks - I'm going to go with this as the answer! "EGR Cooler Top Hose"
I was focusing on connector but ford garage sell it with host as one unit.
Old 26-02-2015, 05:32 AM
mouters
mouters's Avatar
Mark - see picture 5 where hose goes to bulkhead - any idea how to release the hose? I have a replacement and can't get the old one out.
I think the idea is to twist the grey end and pull but I can't get it to, do you do if there is a release catch?
Thanks Chris
Old 26-02-2015, 05:33 AM
mouters
mouters's Avatar
RichieST - see picture 5 where hose goes to bulkhead - any idea how to release the hose? I have a replacement and can't get the old one out.
Thanks Chris
Old 26-02-2015, 05:48 AM
RichieST
RichieST's Avatar
Sorry afraid I have no idea!
Old 26-02-2015, 01:28 PM
mouters
mouters's Avatar
Ok figured out how the joint works - see here
https://passionford.com/forum/6565520-post2.html
salsheikh
Ford Focus ST Parts for Sale
06-10-2019 07:56 PM
marky_g
18
26-08-2015 03:42 PM
Ben26
Ford Focus Diesel
18-08-2015 03:42 PM
taylora1409
12-08-2015 12:06 PM
Quick Reply: 2008 1.8 Diesel Focus Estate - Coolant leak found - what's this called?
