mondeo mk3 no injection signal
Hello Guys!
Im new here, you are my last chance!
I have a 2004 mondeo HJBB 115hp. My problem is the 3rd and 4th injectors dont work, I have checked the connectors, they are dead.
I have checked with mulimeter, no signal .1st and 2nd have signal.
I have checked all the wires to the ecu all good,
No fault code in the ecu at all.
I dont understand because 1&4, 2&3 are on one +line in the ecu
before we renewed diesel pump, injectors were checked cleand, measured compression: 30, 28, 27, 28. changed CMP sensor and Crankshaft sensor.
So everything should be ok, BUT
Sorry for my English but Im Hungarian:
Kind regards: Peter
Kind regards: Peter
Hello Guys!
Huston we got a problem!!
It looks like there is a TDDI Flywheel instald!!!!!!!!!!!!
WE bought the car from Germany, so congrats to the mechanic who Put it in!
But still not sure of that this causing then problem.
Any idea??
Kind Regards Peter
Any idea??
Kind Regards Peter
mk3ste
17-10-2021 10:09 AM
wowk
30-03-2021 07:49 PM
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
