what to use to bodge a sump up........
Girlfriends £200 punto is weeping oil from front of sump, needs topping up every few days!
It's not worth doing properly so any advice to bodge it? I was thinking tiger seal all over sump when it's been cleaned up?
Cheers all!!
Cheers all!!
whatever you do it needs to be clean and dry which is difficult to do if your not removeing the sump, it will weep a little oil for ages unless its emptied and cleaned from the inside.
if you can get it clean and dry I think I would jb weld a piece of tin to it, ive jb welded a self tap screw in the bottom of a block that was porous and leaking a jet of water in the sump and its still going strong so far, touch wood lol
Fix it properly or buy her a new car. If the zorst won't go back on then chuck a new one on, it will be £100 or less
A new sump is only £30ish from your local parts people and you DO NOT need to take the exhaust off to replace them either as the sump slides out no problem. I do about 3 a month for customers and it will only take you 30 mins tops to remove and replace. Just make sure yo leave the sump glue to dry for a few hrs before you put the oil back in and then your ready to go again.
natehall (06-11-2014)
