No fuel at the injectors when cranking
Old 26-09-2014, 09:37 AM
RetroTed
RetroTed's Avatar
Default No fuel at the injectors when cranking
Hi all, help needed again
The series one won't start again
There's no fuel getting to the injectors however the car fires for a second and the plugs are wet so I assume the cold start injector is getting some fuel in. There's fuel getting to the metering unit as I have checked but none coming out of the 4 fuel lines
Now the car will go if bumped and runs not to bad but will not start off the key
Battery is new as are the tank, lines, filters,plugs dizzy etc etc
Any ideas pls
DixieTheKid
11
06-06-2020 11:20 AM
NZWINRZ
Ford Focus RS
28-01-2020 09:24 PM
155lee
27-10-2015 04:55 AM
cos elle
16-09-2015 06:37 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: No fuel at the injectors when cranking
