track controll arms
track controll arms
im trying to put the suspension back on my 3 door sierra cosworth, if i put the track controll arms on first i cant get the antiroll bat to fit its to wide, if i put one track control arm on then the anti roll bar a cant get the other track control arm to line up its about one inch out i cant push it in far enough, whats the correct way to do it
arbs
i"ve just done my first one in years-last i did was on a 2.8 i a few decades ago-its a real pain on your own-i used a ratchet strap as above-you could use decent quality nylon rope with a bar as a spainish windlass affair[wind to tighten] also
just persevere and you will get there
had a go at it today with a racket strap and it did the job so the front is done, just got to put the back axle back on when i get the beam back from the blasters
SMILER258
28-09-2015 09:04 AM
