1.6 Zetec-Se Rebuild
What am I missing off this list for rebuild? It feels like I've forgotten something and its been over two years since I rebuilt an engine and I've never done a S/SE engine.
Top End Rebuild
Rocket Cover Bolts- £
Rocket Cover Gasket- £
Valve Stem Seals - £
Head Bolts - £
Head gasket - £
Inlet Manifold Gasket - £
Exhaust Gasket - £
Cam Belt Kit - £
Spark Plugs - £
Camshaft Sesnor - £
Water Temp Sesnor - £
Bottom End Rebuild
Piston Rings - £
Con Rod Bolts - £
Main Bearing set - £
Big End Bearing - £
Sump Gasket - £
Sump Bolts - £
Oil Pressure Sesnor - £
Crank Sesnor - £
Thomastat Bolts - £
Thomastat Housing -£
Thomastat - £
Water Pump - £
Flywheel Bolts - £
Oil Filter - £
Dip Stick tube O Ring - £
Crank Case Beather Gasket - £
Crack Case Beather Bolts - £
Thanks.
Top End Rebuild
Head Bolts - £
Head gasket - £
Exhaust Gasket - £
Cam Belt Kit - £
Spark Plugs - £
Camshaft Sesnor - £
Bottom End Rebuild
Piston Rings - £
Con Rod Bolts - £
Big End Bearing - £
Sump Gasket - £
Sump Bolts - £
Crank Sesnor - £
Thomastat Bolts - £
Thomastat - £
Water Pump - £
Flywheel Bolts - £
Oil Filter - £
Thanks.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
