3 door Cossie steering rack play..
Hi All,
I have a problem with the drivers side of a steering rack on a 3 door Cossie.
There is no play side to side in the rack but on the drivers side (steering wheel end) of the rack, there is a good bit of movement on the rack shaft. The rods and ends are good, it looks like there is a bush worn or missing and allowing this movement.
I checked my own Cossie and there is no play in that area.I'm reluctant to strip my rack as it still has the original ford clamps holding the gaitor on!
Is there a bush available for this problem?
Has anyone here had this issue before?
Thanks,
Dave
Thanks,
Dave
03-11-2015 04:08 PM
borboyous
22-08-2015 11:17 AM
