Zetec rear crank seal
Old 04-05-2014, 04:33 PM
Semperboy
Semperboy's Avatar
Default Zetec rear crank seal
Hi guys, just took my zetec out of the anglia as i had a slight oil leak from the rear, took the flywheel off and when the engine was tipped it let oil out of one of the flywheel bolt holes! is this normal and the flywheel bolts should create a seal or is this very bad ha!
Old 05-05-2014, 01:03 AM
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
this is normal without any bolts to seal the holes up.
James Porter
28-10-2015 12:17 PM
155lee
14
22-08-2015 12:15 PM
Caddyshack
19-08-2015 07:29 PM
st220kyle
16
14-08-2015 06:13 AM
lockie
31-07-2015 10:03 PM
Quick Reply: Zetec rear crank seal
