Sierra saph 2.0 dohc to cosworth yb questions
Hello good ford people. I have a few questions to ask.
I have a sierra cosworth replica that i love to bits. Ive removed her from dsily drive duties now ans doing some much loved tlc. During that time ive discovered that the engine needs a fair bit of money spent and i dont really want to waste the money on it as i planned to do a convertion later on, so i thought id do it now.
Firstly i know its never going to be a real cossie but i dont care. I will never sell this car so i want to do it and i have traders insurance thŕt know my plans for this car and dont mind atal.
My questions are.
Do i need to change the interior loom to enable cossie engine loom to just plug in? Or can i just plug in the cossie loom to the original loom?
Im a mechanic with my own fully equipped workshop so im more that good enough for major wiring mods but i want to find out the simplest way around getting a simple averagly powered yb running in it
Thank you jon
My questions are.
Thank you jon
Resident Wrestling Legend
when you remove the battery you will find there is a loom that goes around there or under there and into the car
somewhere along that section of loom will be either 2 or 3 8 pin multiplugs that carry all the connections to the car
it will be a start at least
There's only 4 wires on a Cosworth loom that are on the same plug that need to connect to what you have in the car
12v live
12v ignition
Water temp
Tachometer
The 12v is simple enough
The ignition can't go to a wire taken off of something like your stereo aaa when the car is cranking stereo 12v wires and other items inside the car like that are earthed and you'll be podding in the wind for a long time if you don't know this, so find the correct 12v ignition wire
The starter wiring can stay the same as can your alternator, old engine loom can be cut and taped off or just left as I've done with mine
Keep your earth wire from bell housing you'll need that
Your Cosworth engine loom should have 2 relays make sure they are working or you'll run into trouble and a new fuel pump loom is more then ideal
And last piece of advice I'll give you with regards to wiring I'd don't fit wasted spark as you'll be pissing in the wind for months wondering why it doesn't work
You'll have a lot of trouble finding a second hand loom these days that actually works so your best off contacting Ahmed who can make you a brand new one that'll be reliable and he labels it all that much easier to fit
12v live
12v ignition
Water temp
Tachometer
Thanks for the advise guys. Thats a great help. Do you know roughly how much he would charge for a bog standard new loom?
Also would my prop fit or do i need a cossie one? Ive recently bought a completly refurbed lsd rear end with 4x4 rear brakes but i havent collected it yet so i cant see if it fits
Ah ok that'll be for sale aswell then. Are the mt75 boxes worth much?
I think ill try and sorce a loom and just repair it if needed as is idea will cost enough anyway lol
12v live
12v ignition
Water temp
Tachometer
12v live
12v ignition
Water temp
Tachometer
