Small Turbo Cambelt TDC
Hi all
This has probably been covered quite few times, but looking over the threads all I can find is images of crank pulley's with 4 lugs on them. My Crank pulley hasnt got for lugs, its got a full set of teeth with a gap as if one was missing.
I am guessing its a 36-1 pulley, so where is TDC on this beast....
Many thanks in advance
Thanks guys for all your input. I must admit I would have thought the markings would have been more obvious to see, mine appears to have none except the missing tooth. I guess the welding rod down no1 is the only way to do this.
Matt Baxter
16-09-2015 08:30 PM
