Focus ST 225 lamda sensor
Old 13-04-2014, 11:37 AM
samh1979
samh1979's Avatar
Default Focus ST 225 lamda sensor
Hi all I have a problem with my 2005 focus st 225 lambda sensor, I had the sensor changed with was a bosch but the light came back on after a few miles of driving.
Q1 is there only one sensor or two or is there more under lining problems
Old 13-04-2014, 11:58 AM
oldford
oldford's Avatar
You have at least 2 lambda sensors and it could be an under lying problem.
What are the fault codes read?
What is the make of the sensor you removed (also Bosch or not)?
Old 13-04-2014, 12:35 PM
Carlos-Titx
Carlos-Titx's Avatar
Are you running a decat?
wheelwizardrefurbs
24-09-2015 08:35 PM
Dr. Ickxs
15-09-2015 10:15 PM
mike elsome
14-09-2015 04:08 PM
Si B
12-09-2015 06:49 AM
mike elsome
Ford Range
09-09-2015 05:05 PM
Quick Reply: Focus ST 225 lamda sensor
