Help wiring in the mk4 fiesta boot switch
Old 03-04-2014, 06:34 PM
Mk4 Rick
Mk4 Rick's Avatar
Default Help wiring in the mk4 fiesta boot switch
Ive got a universal boot soloneid.I can reverse polarity so it pushes or pulls there is just two wires.Ive got the mk5 fiesta boot switch with 3 wires 1 earth 1 live and 1 for the light.The soloneid is mounted got it all working just need to sort it now so it runs off the switch.Any help would be great because its doing my head in
Old 03-04-2014, 06:42 PM
funkyboozer
funkyboozer's Avatar
Ground one side of the solonoid, power the other side from the switch. The switch should have an input, and an output when pressed. If you've got a test light or a multimeter it'll be simple to see what's what
Old 03-04-2014, 06:46 PM
Mk4 Rick
Mk4 Rick's Avatar
Will it need a relay
Old 03-04-2014, 07:00 PM
dojj
Resident Wrestling Legend
dojj's Avatar
i fitted a switch to my fiesta, simply took the power from the radio to the switch via a fused link, then from the switch via another fused link all the way to the boot via the roof lining from along the a pillar
GVK.
GVK.'s Avatar
I would wire it up through a relay to save the load of the solenoid going through the switch, as above you need to know what terminals do what on the switch you have, so you know if pressed which pin is an input/ output, use a ohmmeter/buzzer to test the switch then wire it up something like this..
Old 03-04-2014, 07:21 PM
Mk4 Rick
Mk4 Rick's Avatar
The black wire that i thought was an earth might be a live its looped.Ive had a multimeter on it and I get a reading from all wires
Old 03-04-2014, 07:34 PM
dojj
dojj's Avatar
one is earth
one is illumination
the others make the circuit when the button is pressed
Old 03-04-2014, 08:32 PM
Mk4 Rick
Mk4 Rick's Avatar
Originally Posted by dojj
one is earth
one is illumination
Im guessing the black is the earth because its looped for the light and the switch.Do I connect the live from the soloneid to the switch with a 12v feed as well
Old 03-04-2014, 08:56 PM
dojj
dojj's Avatar
without going to the car i can't tell you mate, but apparently the earth is the earth, one is for the illumination and the other feeds the boot popper
it's too late to go and have a look now but if you can wait till the morning (and if the mrs doesn't take the car) i can pop it out and have a look which wires did what
Old 04-04-2014, 04:14 PM
Mk4 Rick
Mk4 Rick's Avatar
Cheers mate this one has baffled me lol
Old 04-04-2014, 04:53 PM
dojj
dojj's Avatar
the car will be back in about an hour so i'll let you know then
i ain't forgotten
Old 04-04-2014, 09:51 PM
Mk4 Rick
Mk4 Rick's Avatar
i ain't forgotten
Cheers mate
Old 04-04-2014, 09:55 PM
Mk4 Rick
Mk4 Rick's Avatar
I tried doing it before but the boot kept opening even before I press the button.Ive earthed the soloneid and earthed the switch.I connected the live from the soloneid to what I think was the live the (black & white wire) and put a live to it as well and the boot opened with out me touching the switch.I even thought about adding a relay?
Old 05-04-2014, 10:21 AM
Mk4 Rick
Mk4 Rick's Avatar
Looking at this picture here everything looks ok but where do I put the live from the boot soloneid lol
85 is ignition lie 12v
86 is earth
30 is permanent 12 v
87a is permanent feed to boot popper switch
87 doesn't get used ?
But where do I put the live wire from the boot soloneid?
Old 05-04-2014, 01:18 PM
dojj
dojj's Avatar
not the best pic but the yellow wire and green wire is the live feed to the switch
and when you press the button this powers up the grey wire
so in your picture, the top black wire gets power, and the 4th wire along gets the power when it's pressed
you don't need to do any other buggering about so chop the connected wire first as this is whats causing the problem
Old 05-04-2014, 01:22 PM
Mk4 Rick
Mk4 Rick's Avatar
Chop wich connected wire?and where do I put my live wire from the soloneid and which is earth
Old 05-04-2014, 01:26 PM
funkyboozer
Orange/yellow is ignition or accessory live. Black earth. Black/ yellow to solonoid.
The factory setup doesn't use a relay as the solonoid only draws about 10 amps at the most.
Old 05-04-2014, 01:31 PM
dojj
dojj's Avatar
top left corner is live feed in
top right corner is switched feed once you press the switch
anything else you need to make redundant so cut the looped wire from the top left to bottom left as per the pic
Old 05-04-2014, 01:32 PM
dojj
dojj's Avatar
also, have you got a continuity tester?
put it across the terminals and see which one does the pass through when you press the switch
Old 05-04-2014, 01:40 PM
Mk4 Rick
Mk4 Rick's Avatar
Ive got that bit now which bit makes an earth
Old 05-04-2014, 02:00 PM
dojj
dojj's Avatar
you don't need to earth it, i think that's where you've been going wrong
you only need to power the switch (via a fuse) and then send the wire to the motor to power it
Old 05-04-2014, 02:11 PM
Mk4 Rick
Mk4 Rick's Avatar
Dojj im now beginning to question the wires on the switch.I took the multi plug out of the switch and ive got an extra to spades but not for the wiring.
Can I have an actual picture of underneath your switch for the wiring please.i got it off ebay I did a test on it and when I press the switch it moves.You have three wires running off the back of your switch looking from the picture.
Old 05-04-2014, 02:13 PM
dojj
dojj's Avatar
i've got 4 wires running off the bottom mate, but only 2 of them are connected as i didn't want to chop the wires too short
Old 05-04-2014, 02:20 PM
Mk4 Rick
Mk4 Rick's Avatar
Dojj your the man ive done it.It was top left like you said and the power from the soloneid going to the black and yellow wire with the black loop cut.When you look at some thing for so long it starts to drive you round the bend.
Thanks for your help Dojj
Old 05-04-2014, 03:36 PM
dojj
dojj's Avatar
glad you solved the problem, and look forward to many years of button popping boot openings
Old 05-04-2014, 04:29 PM
Mk4 Rick
Mk4 Rick's Avatar
xrmalin
13-09-2015 06:52 PM
hopper350
04-09-2015 12:53 AM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
Quick Reply: Help wiring in the mk4 fiesta boot switch
