Cosworth L8 ECU
Cosworth L8 ECU
Hi all anyone live near Burton or local so i can test my L8 ECU in there car to see if it sparks, just need to rule out my ecu with sparking issues, sometime it will spark then it wont, had new phase sensors, crank sensor, coil leads, coil, plugs, so on so on, so can some one please help me out.
No mate had four new amplifiers, was running wasted spark, but i started to get an issue with that not sparking, so i reverted back to coil and dizzy, every sensor is new, every wire i have belled out resistance checks, only thing left is the ecu i think.
I could travel to test my ecu thats how desperate i am to find out if its ok or not. The ecu only uses 2 earths 1 and 19 i think from ecu
I'm neverar Blackpool if it helps u in any way? My gfs from your way but don't no when we are going visiting her family again soon. Dose the car drive? And are you taking it to pod? As I can bring a ecu with me for you to test out?
Inbox me your details and will try to help you out, stop off on way back from ford fair. Surprised no one more local,to you won't offer to call round and help you out
There was an issue with the phase sensor wiring, he gave me a scope of work to look at and that included the phase sensor wiring. A good bloke spent hours on the phone.
big_Rad
15-09-2017 09:36 AM
