Escort rs turbo s2 cuts out when hot
Old 10-03-2014, 08:37 PM
yorkierst2
yorkierst2's Avatar
Default Escort rs turbo s2 cuts out when hot
Hello guys
Can anyone help me, i have a grey escort rs turbo s2. When im driving round town or if i just leave the car to warm up on the driveway it will get upto temperature and the cooling fan will cut in and out a couple of times then the car will just cut out for no reason.
If you try restart it, it will just about start and run at about 600rpm with my foot flat on the accelerator soon as you let off it cuts out. So this leads me to beleive it's sudden under fueling issue due to heat build up in the engine bay. If your out on the open road it's fine.
After a couple of minutes it will start and run fine again until it gets hot again under the bonnet (in about another 10mins) then it does the same thing again.
The fault is replicatable everytime but you don't have long to diagnose it before it goes back to normal.
Any help would be appreciated, ive services the car (oil, oli filter,plugs,cap,rotor arm,fuel filter) and swapped the dizzy for another one but it's still the same
Old 10-03-2014, 08:42 PM
turbowag
turbowag's Avatar
U could try a new cold start valve, used to give me similar problems on my old rs1600i turbo
Old 10-03-2014, 08:46 PM
yorkierst2
yorkierst2's Avatar
I could try unplugging it when it's having an episode see if it makes any diffrence. Im sure it's under fuelling not over but i am willing to try anything. thanks for the suggestion.
Old 10-03-2014, 09:08 PM
turbowag
turbowag's Avatar
Yeah its gotta be worth a go
Vincereese
01-06-2023 09:14 AM
3i Jim
20-11-2015 05:12 AM
Vincereese
18-08-2015 03:57 PM
muz
16-08-2015 12:57 PM
adriansaleem
01-08-2015 09:28 PM
Quick Reply: Escort rs turbo s2 cuts out when hot
