53 Mondeo 130 TDCi handbrake adjustment
Old 17-02-2014, 09:11 PM
Mondeo Les
Mondeo Les's Avatar
Default 53 Mondeo 130 TDCi handbrake adjustment
Failed the MOT as apparently the brake works fine but the lever comes up too far. I understand it has a self adjuster but clearly something s wrong.
Any fix available?
PS - unfortunately I got the guy who likes to fail on an much as possible i.e. curly corner on the numberplate (!), wrong colour indicators, slightly rusty brake pipes, miss-aimed washer jets........... Mmmm... I know some may be legit but frustrating none the less.
Old 17-02-2014, 09:22 PM
dojj
Resident Wrestling Legend
dojj's Avatar
if it's self adjusting then it's normally the cables that stretch and fail, £15 a side from the factors and easy to fit
if it's the mechanism then it's a pain in the arse to removebut just make sure you have a working replacement to refit
they went manual adjustment after 04 i think and the fittings ont he end are different too
Old 17-02-2014, 10:40 PM
GVK.
GVK.'s Avatar
If it is a self adjusting one - Should have had a recall YEARS ago to replace the lever with an adjustable one.
Self adjusting ones used to play up, they bought out a bodge at first then, a recall to replace the lever.
17mm nut on a threaded bar on the lever, under the car, exhaust heat sheild needs dropping to get to it.
Old 18-02-2014, 06:42 AM
Mondeo Les
Mondeo Les's Avatar
Thanks guys.
Bought car at three years old and up until then it had never had a recall applied. Any since then I wasn't aware of.
I'll drop the heat shield just in case there is an adjuster. Then probably get down to the factors :-(
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
wowk
30-03-2021 07:49 PM
Brickhouse
14
03-10-2015 07:28 PM
Fezman1
02-10-2015 01:22 PM
The Enigma
29-09-2015 10:31 AM
Quick Reply: 53 Mondeo 130 TDCi handbrake adjustment
