Cosworth Oil Temps
Cosworth Oil Temps
I was hoping you may be able to give me some advice regarding Oil temps on my Cosworth powered race car.
Whilst racing it last year at Oulton and at Combe I became aware that the Oil Temps were up to about 130 Degrees Celsius. Water Temp was a Steady 95 degrees Celsius and when lifting off after the Chequered flag quickly returned to 85 degrees.
Should I be concerned by the Oil Temps ?
The car has a Sandwiched oil cooler / inter cooler / radiator and the cooler is first in line
Any advice/thoughts or experiences on this subject would be appreciated
Picture to illustrate the position of the cooling setup (I haven't got any stationery stills of the front)
Cheers Ian
Cheers Ian
Harryh24
26-08-2015 07:50 PM
COSWORLD
14-08-2015 07:40 AM
