swopping 1.8 dash clocks for st? mondeo mk3
Spanner monkey
Should be mate, i fitted a set of St petrol clocks to my old TDCi, all i did was add the glo plug lamp in but yours being petrol should be plug and play, AND the milage will be the same as its stored in the pcm, not the clocks!
ST if petrol is a V6 so surely the rev counter won't work properly on a 4 cyl?
Had a look an no mention of being part of immo on these, only linked to PCM/ABS/ESP via CAN.
The instrument cluster is a mix of intelligent and hardwired electrical signals and has a built-in self-test feature. The instrument cluster is connected to the powertrain control module (PCM), anti-lock brake system (ABS), traction control (TC) (if equipped) and stability assist (if equipped) by a control area network (CAN) bus. This link allows the instrument cluster and the PCM to communicate with each other. The instrument cluster consists of gauges and warning indicators. On the high series instrument cluster a trip computer is fitted to the information and message center.
