help needed got an st2 with a problem car is running and driving mint but when I hit 4500 rev the car loses power and revs increase slow, the clutch is good and decated so it isn't a blocked cat or clutch. I have a code reader no codes so help plz
Hi,
How far up is the boost gauge getting? it is very very common for the boost solenoid to fail on these.
If the car is standard it should boost to just over half way. when my solenoid failed i was getting 1/4 right up to redline
