Help Reqd - 2005 Focus - Banging noise under accelleration....
Old 10-01-2014, 08:04 AM
stuntmonkee
stuntmonkee's Avatar
Question Help Reqd - 2005 Focus - Banging noise under accelleration....
Hello all. Got a problem with my daily driver (55 plate Focus Sport 1.8 TDCI, 120k miles) I was hoping someone might have experienced before.
If I accelerate (even slightly) on a rough surface, hit a defect in the road while gathering speed or while braking over slightly rough/bumpy surface (most of the UK’s road at the moment) the car will shake the steering wheel and bang very loudly & violently from the front. It feels like the front of the car is about to fall off. If you then bake off the accelerator or brakes it will cease. It’s been like it about 6 months and if I remember it started getting worse gradually, not a sudden failure as such.
It had new wheel bearings on the front both sides last month which made no difference either way (not that I was expecting them too). I didn’t notice anything especially untoward while changing the bearings (all drop links intact etc) while doing the bearings but admit I only had a half hearted examination (it was freezing cold that day).
I’ve got to fit new discs & pads next weekend and it would be good to have an idea of where to concentrate my investigations – in my mind I’ll start by examining the bottom arms?
Any advice gratefully received, cheers
Old 10-01-2014, 08:24 AM
Rob Virgo
Rob Virgo's Avatar
Top mounts or arb mounts ??
Fudgey
17-09-2015 01:06 PM
talon1
15-09-2015 10:27 AM
Flateric_2002
15-09-2015 08:41 AM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
rsturbo27
05-09-2015 05:08 PM
Quick Reply: Help Reqd - 2005 Focus - Banging noise under accelleration....
