Key Issues - Ford Fiesta 2001
Hey all
I have some serious key issues on my Ford Fiesta.
When I bought the car I was given 3 keys. Two of them are bona fide Ford black keys with a red chip in the top. One of the keys has stopped working completely and the other one will only start the engine and not open the doors/boot.
The 3rd key looks like one that has been cut from a key cutting shop and will open the passenger door and boot but will not start the engine.
I can't unlock or lock the driver door... not sure if this is because all the keys are broken or if the lock itself is dodgy.
Is there a cheap way I can get a key cut that just opens all the doors/boot? I have a key that starts the engine so that is not too much of an issue.
Yeah, they need coded. Some Timpsons do key programming now, but avoid.. They charge an absolute fortune I've heard...
Some places online can send you keys cut to copy for about a tenner each incl. postage, all you have to do is send a picture of your key blade and they send a replacement.
Then you can swap the chips over. Be careful if you do this method, they're made of glass. if you break it - it's fooked...
Another option is just to get a local auto locksmith to come out. Fords are about the cheapest and easiest to do in the biz, so you should get a deal.
He'll be able to test the keys and make sure all the chips are okay/working if any the keys you have turn the ignition on, but not start.
And if he's any good he could repair door locks/replace bits inside if it IS the locks that are at fault.
Common on Fiestas, Ka's + Courier vans... little pin inside locks rusts and doesnt drop down when the keys inserted/turned. Done a few of them...
JoeyBoyden
04-01-2024 02:36 PM
vdun01
Ford Fiesta
05-10-2017 08:14 AM
