Mk5 escort fusebox - ecu and abs power
Thought I'd ask on here as my escort mk5 has some strange symptoms
What would cause loss of power to certain circuits in the fusebox?
I can fit another busbar and get ecu power to the starter/alarm/ecu relays
But still no power to the abs system
I'm still thinking it's electrical but can't seem to find any issues
Fuses ok at the battery and fusebox but something is a miss
I'm guessing the only way to find out is strip the loom and see if I have burnt out wires in the loom
But before I do this I want to know if someone has had something similar
Oh changed fusebox, relays, abs pump, abs ecu, pedal switch
