Alloy hubs- cortina uprights- which bearings?
Hi all,
I purchased some mk3-5 alloy hubs, and separately some cortina uprights. They're pictured.
I tried fitting standard cortina bearings (mk3) and the hub body appears to be too long and the bearings don't pull home. Is there a different bearing I should be using?
Thanks
Steve
Thanks
Steve
I just think the bearings are absolutely incorrect. Should the bearing races sit on the widest diaper (shown in the hub pic) or the smaller one? Currently outer one only sits on the smallest dia.
