Siemens injector in yb fitting problems
Just fitted my Siemens 83lbs injectors in my Cosworth but have a problem. Thought they were direct fit so fitted them straight in the inlet but I know have a gap between the inlet and the bottom of the ejector body.
The injectors came from msd new a few years back.
Looking at the picture the o ring seems to be fully home in the manifold and since your running a standard rail with securing clips the injector can't move so should be fine.
The problem comes when running billet rails without the clips where the injector can move out, in that case you have to fit a washer to stop them from moving.
Looks fine, what he says -
Stu @ M Developments
41
21-08-2015 06:47 AM
