2.0 zetec turbo conversion into a mk4 erst
Hi guys, busy trying to sort the wiring looms out so that i only have one loom, i have the complete engine and ignition loom from the mondeo donor car with the the transponder, key and ecu, has anyone got any pics or links to which wires go where and which ones can be done away with, the ecu im using has BASH code on but this should be ok as im using a piggy back ecu, please help
big_Rad
15-09-2017 09:36 AM
