Rs2000 van conversion wont idle properly and cuts out under acceleration?
Hi, any help would be greatly received..... escort van with a rs2000 conversion from a 1997 donor car.
The problem im having is the car wont idle as it should and is hunting slightly, will rev up but coughs n splutters but will complete the whole rev range, but if i try to drive away it just wants to cut out and coughs n splutters, i can coax it if i only very slighty touch the accelerator but as soon as i try to give it any throttle it just dies, checked the plugs and they was very black so i have put new plugs in and its still the same, idle control valve has been replaced with a brand new unit and the car is still the same..... what should i be looking for next, coil pack seems to be sparking all 4 plugs.. The van was driving perfect after the conversion, ideas where i should be heading?
I think you can rule out fuel starvation and/or the fuel filter.
Black spark plugs point to overfuelling. Maybe a defective sensor?
Get it on a diagnostic machine and check the sensor signals.
hi, ive got a odb11 reader, is there a odb point on these cars/vans as i thought they wasnt really around then, also what should i be looking for if they have, thanks
The 1997 engine you used does normally have a 16-pin diagnostic socket.
Whether your car has it? I have no idea about the model-year and what kind of engine was in it.
Did you use the wiring loom and ecu from the 1997 donor-car?
Did you also include the 16-pin connector and it's wiring?
Hi sorry for the delay, my mechanic said my fuel pressure was sky high & he adjusted the octan by the black triangle 3pin plug on the inner wing just behind the air box on mine hope this helps you get it sorted.
