Cossie head re-build /preventative maintenance
Hello
My yb 4x4 turbo motor is in need of some tlc after a new oil pump was fitted which then blew out the core plug that caps of the oil way drilling on the pump which once warm then lost oil pressure the bottom end I can do my self but am looking for a reputable place to send the head there was no oil starvation to the head but would like to have the guides checked etc just because its in bits the head has had some porting and is running Kent bd14 cams inlet and exhaust I'm in jersey so would need to ship it were ever just want someone well recommended
Also can any one crack test and pressure test the oil ways in the block recommendations please
Thanks fanny
Thanks fanny
JK12
33
26-04-2021 12:09 PM
