1300-1.25 wiring loom/ ecu
will the 1300hcs wiring loom and ecu pin numbers be the same and work when i change over to 1.25 zetec engine and ecu.
ive took the loom from the zetec when i removed engine but its been cut through and the haynes manual is unclear. ie the zetec ecu/loom pin numbers are the same as the 1.3l endura in haynes and has no resembelance to the 1.25l diagram in the haynes manual.
so to cut a long story short can i use my original loom and lengthen where needed.
Hope all this makes sence
TPM961
15-01-2018 10:50 AM
Mark RS
12-10-2015 06:01 AM
