Zetec pre pats looms + ecu
Hi
Im going to be converting my mk4 to a blacktop 2.0 zetec i know i preferably need pre pats loom and ecu
I have found a 1.8 130spec escort cab wiring loom and ecu from an L reg with ecu code COPY
Would this work? if i was to swap the ecu for the pre pats 2.0 version?
Thanks for your help
Is the guy above me right? Ive not bought anything yet as nothing is coming up. Found Rs1800 loom and ecu too but thuats not 2.0
Yes your right but,
(We'll use a rs1800 fiesta as an example)
this car has fuelling controlled in ecu , and spark is done with the edis 4.
If you then changed the engine to a mondeo 2 litre whether it is non pats or not doesn't matter, as the mondeo ecu controls fuel/ spark. No edis 4.
So in regards to your first post, you want to use a non pats 2litre ecu, these are only mondeo . So you can't!
You might as well just use the 130 escort ecu with the 2litre.
Me and a mate have done this in the past .
Hi guys
Thanks for the replies sorry for long delays in replying works really busy!
So ive got 2 choices, The escort 1.8 130bhp loom and ecu i originally posted about or ..
On a side note then, Ive also been offered a fiesta rs1800 loom and ecu. Is this good to use aswell? i assisted in fitting an rs1800 in a ka not long back and we used the loom in there with no problems but i am using a blacktop 2.0 not a silvertop.
Thanks guys all help is appreciated!
Hi guys
Sorry i been away for a while
I got offered a loom and ecu from a fiesta rs1800 for 70Ł yesterday and was told the guy ran his blacktop zetec off this.
Id like to know for definite before i invest that its going to run my zetec fine before i invest??
Thanks in advance for your info!
Is anybody still selling a pre pats loom and ecu 130spec still??
Bought rs1800 stuff and its not as described and absolutely buggered.
Found another rs1800 loom and ecu but the guys telling me its a very late one on M reg and has pats...
Thanks
Thanks
JK12
33
26-04-2021 12:09 PM
DixieTheKid
11
06-06-2020 11:20 AM
TPM961
15-01-2018 10:50 AM
