tuning a fiesta zetec s
Old 22-08-2013, 11:57 AM
fordcozyjohn
fordcozyjohn's Avatar
Default tuning a fiesta zetec s
hi my m8s just got a mk5 fiesta 1.6 zetec s its got a set of cams in it but standard pulleys whats the best way to get more power out this engine ?
Old 22-08-2013, 12:40 PM
martysmartie
martysmartie's Avatar
There isn't really, unless you spend considerable money.
They respond well to cams, then you have things like 4-2-1 exhaust manifold, exhaust and a map to suit.
Martin
Old 22-08-2013, 01:07 PM
fordcozyjohn
just rang ctm tuning bout geting head work dun and he was saying can get up to 25 % more power out of it
Old 22-08-2013, 01:12 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
The heads flow very well as standard and can be left alone until around 150bhp which can just about be had on standard induction bar a decent filter.
Cams, ITB's, a decent 4-2-1 manifold and system on OMEX or equivelant will see you around 160/170bhp, 200bhp can be had with lairy cams and headwork.
Old 22-08-2013, 01:28 PM
It's Czech Mate
It's Czech Mate's Avatar
Standard inlet
Decent cams ( really depends on the right grind)
4-2-1
Exhaust
Panel filter
Uprated rod bolts
Remap
150bhp
add throttlebodies and management and uprated valve springs for 170+bhp
the head flows enough for nearly 200bhp as is
the standard pulleys are keyless so they do everything a vernier pulley can in terms of tuning
Old 22-08-2013, 02:57 PM
kyle_st200
kyle_st200's Avatar
Probably the best thing to do would be puma it and tune that engine. Can be done quite cheap now
Old 22-08-2013, 03:00 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Puma is fine in mild tune, but at the top end you're only realistically going to see another 10bhp at the most. Waste of time IMO.
Old 22-08-2013, 03:11 PM
kyle_st200
kyle_st200's Avatar
Surely got to be worth doing and tuning that than a zetec s? I had a zs when they were fairly new with a k&n and cat back etc and my brother in laws puma zs feels a lot quicker than mine did
Old 22-08-2013, 03:20 PM
fordcozyjohn
thanks for the help this is all good to know
Old 22-08-2013, 03:56 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Thing is, the money you spend on getting everything you need for the conversion, you could put into the 1.6 and have more power.
That's probably because your K&N and catback gave you maybe 5bhp if you're lucky lol.
Old 22-08-2013, 04:06 PM
kyle_st200
kyle_st200's Avatar
I know I will of had minimal gains I was just pointing out that rather spending the money tuning that you may aswel puma it. I'm sure it only cost my brother in law about Ł400 to puma his which like you said my k&n and cat back was similar money and gave minimal gains whereas going the pula route is more power per Ł
Old 23-08-2013, 10:19 AM
rsmark86
rsmark86's Avatar
There's no way a 1.6 zetec s engine does 200bhp on a stock bottom end lol
You would need a full race engine to make 200bhp and spend thousands, 160/165bhp is possible with cams, throttle bodies, 4-2-1, full decat system, head work, arp rod bolts
If you think I'm wrong show me proof, people are reading to much into pumaspeed claims,
Full race exhaust and throttle bodies will make around 150bhp so add 10/15bhp max for head work and cams
Old 23-08-2013, 10:33 AM
CrOwSoN15
Ben
CrOwSoN15's Avatar
I honestly don't know how I managed to forget about the bottom end lol.
Burtons did something like 197bhp on standard rods, but it wouldn't last long.
You only need to touch the head if you're going for 170+, they flow fine even at that level.
Old 23-08-2013, 10:51 AM
asha1
asha1's Avatar
I'd go Puma route to be honest, got a puma'd mk5 zs myself with cat back & k&n - granted its not the fastest thing on the road but it is bloody quick up to 4th ! I've found tuning is *quite* limited on the 1.7 though, can get FRP inlet, FRP cams, HD Big end bolts & FRP map, 4-2-1, should apparently get to around 150bhp - 160bhp (so i've read)
or if you can get hold of 1, an FRP engine.
Old 23-08-2013, 11:40 AM
It's Czech Mate
Pointless when a 1.6 can be modded for 150bhp on the standard plastic inlet
Cams, rodbolts, exhaust, 4-2-1 and a map...away you go
I've had a few of these done now in various cars and its a piece of cake
These engines are superb, breathing is heavily restricted as standard but the right cams and inlet/exhaust mods will release its potential
Super light too
The right cams are important tho, speak to Shawspeed.
if you want to tune the 1.7 its basically the same engine and you can do the same stuff but its a pain incorporating the vct or removing it so you may as well start with the 1.6
Theres a reason all the kit car companies use them
Best mod to a standard one after the usual exhaust/filter..........retime the exhaust cam or a RR
Old 23-08-2013, 12:11 PM
asha1
asha1's Avatar
That's the only pain in the arse for me, VCT ! as I bought my ZS already puma'd there would be no point me going back to a 1.6 I reckon, think I was thinking of my case too much
I guess in the case of the OP, doing all that would be worthwhile I guess, but what kinda cost's are involved ?
Old 23-08-2013, 12:20 PM
martysmartie
Agreed.
Martin
Old 23-08-2013, 12:51 PM
It's Czech Mate
Doesnt need headwork for under 200bhp the valves are plenty big enough
A polish helps a little
bodies without cams are a waste of money, the cams are cheaper and can be set up using the existing management, bodies cannot, therefore the cams first is the way to do it (150bhp) then add bodies for over 150bhp, this is where it gets pricey with standalone management required, however ALL n\a cars are 'pricey' to tune and this one gives particularly good results if you're starting from base
also ARP do not make rod bolts for this engine last time I looked
you will also need to think about valve springs if you raise the rev limit much above standard
For the record, Pumaspeed have always been full of shit, Pumabuild are a little better but not massively so.
Old 23-08-2013, 05:55 PM
rsmark86
rsmark86's Avatar
I was just making it clear that you would not see 200bhp on a stock bottom end, I know about needed management as I would never try fitting bodies without
If I wanted decent future mods I would save my money and fit a 2.0 st150 engine, as cams and bodies with decent exhaust would see 200bhp although it can be done with bolt on mods
And there's all the turbo and supercharger kits out their too
Old 24-08-2013, 10:42 AM
martysmartie
He said BOTTOM end!
Martin
Old 24-08-2013, 04:59 PM
It's Czech Mate
Originally Posted by martysmartie
He said BOTTOM end!
Martin
He also said lots of other things too, some mildly misleading and some incorrect hence my post
Hth
Old 24-08-2013, 11:56 PM
rsmark86
rsmark86's Avatar
if im honest i would pay too see one make 200bhp on a stock head and bottom end in aspirated form, an st170 struggles to clear 200bhp with throttle bodies and management
i just cant see it happening when i have the experience of having professionals build me worked redtops and aspirated cosworths and the time and money and work needed to clear 200bhp is mental
the small 1.6 would need to have some serious work done to clear 200bhp in n/a form, if it was the case of banging on a throttle bodie kit and cams with forged pistons and steel rods to one of these engines to clear 200bhp then everyone would do it, so what your saying is it doesnt need any porting ect?
Old 25-08-2013, 10:39 AM
martysmartie
Agreed, it will never flow for 200HP
Tbh that figure and that size of engine don't go hand in hand.
Martin
Old 25-08-2013, 11:27 AM
Wardy ZS
Wardy ZS's Avatar
Depends what you want to spend.
ZSOC.com has some varied projects.
Anything from a mild engine, upto 300bhp turbo Sigmas in a kit car.
For tuning, ShawSpeed are most popular for the 1.6 and LMS (Lightning Motorsport) for the 1.7.
I'm running 160-170 with a standard bottom end, mild headwork, cams, ITB's and aftermarket management. Rough cost to build mine would be Ł3k to Ł4k.
200bhp is possible, but you will need forged bottom end, headwork and lairy cams, I'd budget another Ł2k at least up from my spec.
Old 25-08-2013, 01:50 PM
It's Czech Mate
if im honest i would pay too see one make 200bhp on a stock head and bottom end in aspirated form, ths and the time and money and work needed to clear 200bhp is mental
I don't think anyone has said it would clear 200bhp with no head work and a standard bottom end?!?!?! Lol in post 5 I said the bottom end needs a mod to safely hit 150
Old 25-08-2013, 01:58 PM
It's Czech Mate
I've seen 190-195 with no headwork other than a polish
Any amount of headwork won't improve this unless you can work out a way of using bigger valves
This is based on having had 5 of these engines in the family in various states of tune over the years, one in a fiesta and four in various kit cars.
Old 26-08-2013, 12:07 AM
martysmartie
"the head flows for nearly 200hp as it is" as stated by you in your first post?
Martin
Old 26-08-2013, 05:47 AM
It's Czech Mate
Martin
I'm not sure why you're being so argumentative, you are saying your love to see one doing 200bhp on a standard bottom end and no headwork.
Nobody has ever said it would if you read back.
Feel free to carry on guessing what you can do with a sigma, I'm happy to sit here with the knowledge of what I have done.
Old 26-08-2013, 10:34 AM
martysmartie
I'm not, and no I am not saying that, it's pretty obviously it would need work on the bottom end, it's hardly a strong engine to start with.
The fact I am stating is that you said the head will flow for 200HP, which is incorrect as it would need work (which you later said, by your own admission) which is the point that Mark made as well.
Tbh, like I say, I seriously doubt that figure anyway, in N/A form.
Martin
Old 26-08-2013, 10:39 AM
SmudgerByName
Ford Fanatic
SmudgerByName's Avatar
I'm considering some tuning on my ZS over the next few months so am interested in seeing what your spec is like...
Old 26-08-2013, 11:22 AM
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
Martin
The key word is 'nearly', you just seem to be arguing for arguments sake.
The only time I've seen a 1.6 do 200bhp on a standard bottom end, was with a turbo strapped to the side of it, that also had no head work iirc, but the small amount of boost helped there.
Old 26-08-2013, 11:47 AM
martysmartie
Someone else has raised the same point.
Headwork would be required alot earlier than that (You can see someone already has mentioned headwork for like 160-170HP on this very thread) 200HP is some difference, so not 'nearly' at all.
Martin
Old 26-08-2013, 02:39 PM
It's Czech Mate
Lol, get one on the flow bench with a pro like I did.
I'm out of this one and will leave it to the guessers and theorists.
Old 27-08-2013, 10:04 AM
fordcozyjohn
hi all well i think that hes just going to put a st170 engine in it now
Old 27-08-2013, 10:12 AM
AaronsKa
AaronsKa's Avatar
That's more ball ache than its worth. Find a racing puma engine and ecu and it would give a little Zs quite a kick up its arse!
Old 27-08-2013, 01:57 PM
It's Czech Mate
Not a bad shout
Needs a 16v Xr2i or RS1800 gearbox if you can find one
Again, retime the exhaust cam and thats a lovely conversion IMO as you will have a fairly stock engine and therefore reliability
Old 27-08-2013, 01:58 PM
It's Czech Mate
For the price you'd pay you can extract more power and torque from the 1.6 you have already
Old 27-08-2013, 08:20 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
I feel like we're beginning to repeat ourselves
Old 31-08-2013, 10:34 PM
fordcozyjohn
hi all do you know if the cams out my m8s fista 1.6 zetec s will fit in my gf focus 1.6 zetec ?
Old 01-09-2013, 08:14 AM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Depends whether the Focus has a Zetec E engine or SE.
Quick Reply: tuning a fiesta zetec s
