Cosworth valve stem seals fitting?
I did mine using a small socket , one that sits over the top part and down onto the middle of it, and then gently tap in on, make sure you put a bit of oil on the guide and the seal first.
STOOOOOOOP!!!!
fair play for having a go but be careful. You should really use a valve sleeve to stop scuffing the inside of the stem seal as you drive it down. The ridges that house the collets can cause this and make the whole job a waste of time and money.
Oh and yes a socket is the best way to do this. Allowing the top of the valve to poke out of the socket hole as you push down.
rsstav
Ford Focus RS Parts for Sale.
16-08-2015 08:38 AM
COSWORLD
14-08-2015 07:40 AM
rsstav
11-08-2015 04:22 AM
Red_bull
09-08-2015 08:34 AM
