turbo crank or normal crank
What's the difference between a cvh 1.6 turbo crank and a normal crank and what's the difference between a 1.4 block & a 1.6 cvh block advice needed please
So there is no difference between the cranks
What about if my bores are no good in the turbo block what about getting the 1.4 block bored to the 1.6 size which is 79.?? And the 1.4 is 77.?? Would I be able to do that
No chance of the 1.4 block holding a plus 2mm, and even if it did I don't think the deck height is the same. Proper 1.6 blocks aren't hard to find, even an n/a one would do
James Porter
28-10-2015 12:17 PM
Matt Baxter
16-09-2015 08:30 PM
JoeyBoyden
14
15-08-2015 09:51 PM
st220kyle
16
14-08-2015 06:13 AM
lockie
31-07-2015 10:03 PM
