Cosworth only 1 injector firing help
Hi looking for some advice or to see if someone has had the same problem,
I have just rebuilt my car and only changed ecu and injectors and I am only getting 1 injector firing fuel No2
I have swapped injectors over and still only No 2 firing
I have swapped the map sensor over and a lot the phase sensor and now I'm stuck has anyone else had the same problem or maybe know what is up
Thanks in advance
Thanks in advance
Stu @ M Developments
41
21-08-2015 06:47 AM
