Xr3 gearbox on escort 1.8d van
John
Hey guys
I have a escort 75 1.8d. The gearbox has gone and I currently have a xr3 gearbox laying around. I was wandering if it would fit or is there anything I can do to make it fit.
Thanks
Thanks
Not Crazy, just Unwell
3dr Cosworth owner
Just to double check do you mean you have a xr3i box or a genuine xr3 box as the xr3 had a 4 speed so if fitting this you will need the 4 speed selectors. If it is a 3i box that is 5 speed then you'll have no bother. Will probably make it a bit quicker round town as the shorter ratios but will rev higher overall. It'll be right
John
yeah its a xr3i box i have the 1.8 non terbo engine the mounts look in a differe place because the xr3i box has a cradle under as a mount were as my van has two seperate mounts one at the front and one at the back
i have taken the old van box off and fond loads on iol in the bellhousing so i think the oil seal behind the flywheel has gone :/
also found out whats happened to the old van box a metal bung has come out and some how the gears have shredded so i can not get any gears.
thank you
thank you
