What all do I need to t3 my fiesta rs turbo ?
RS03ASK H575DGA
Is all i need t2 turbo escort rs turbo manifold and down pipe ? or do i need to use different oil returns pipes etc ?
as far as I know you need to use the erst oil supply line, also the oil return stub is required from the erst block.
Air filter will need re working, maybe a erst hose and a cone filter perhaps?
So u are putting a t3 on a fiesta ?
If so u will need:
Beige injectors
195 chip
Escort rs turbo manifold.
Escort t3 downpipe
Oil return stub for block
T3 oil return rubber pipe
T3 water pipes top and bottom unless air cooled
T3 top oil pipe. Back of block to top of turbo
Escort rs turbo top radiator pipe. Unless its a series 1 aircooled turbo then no need.
If so u will need:
Beige injectors
195 chip
Escort t3 downpipe
If so u will need:
Escort t3 downpipe
If so u will need:
Escort t3 downpipe
paceo
03-02-2016 10:31 AM
Ben26
27-08-2015 08:56 PM
paceo
27-08-2015 12:45 PM
