T5 fifth gear ratio's
Hi i am looking at having a 0.68 fifth gear ratio fitted into my 2wd T5 gearbox.
The gearbox is going into an Escort Mk1 Cosworth.
With the small wheels the engine revs to high in 5th
Has anyone had a conversion like this done and point me to a specialist who would do the work.
Any advice would be appreciated
There is no such option for the cosworth t5 as the american versions have a different spline on the output shaft for their 5. gears. You would then have to change your output shaft for an american one, but then your prop shaft wont fit as the splines for the yoke is different.
07-10-2015 12:56 PM
The Youth.
30-09-2015 09:59 PM
