24v BOA wiring from Thermostat housing???
Hi
there are two sensors/wiring on the thermostat housing, I just need confirmation as to where the wiring goes?
Does the single wire (rhs sensor) go to the temperature gauge? and the multi wires (lhs sensor) go to the ecu/fan control??
Regards
Mick
Regards
Mick
two wire is the ECT. Brown/Green is the sensor back to the ECU, Brown/Black is the Reference voltage to the sensor.
The single wire one is the dash coolant temp, Not sure on the colour.
thanks
Thanks chaps - will look at the car tomorrw.
Car is being rebuilt - no battery, engine harness not connected to car harness yet. No coolant hoses and only part of the exhaust is tacked awaiting welding.
Mark RS
12-10-2015 06:01 AM
