fiesta st150. how much power steering fluid should be in resevoir
hi all!
i had a ps fluid change 2 months ago because it was pitch black and have noticed that sometimes now my power steering feels rather heavy car is an 05 plate with only 46k on the clock so i wouldn't imagine the rack failing at this millage
the fluid is still cherry red so i don't think the rack is leaking or boiling up the fluid. also had a garage check it all out and they can find no problem with the rack itself
i have noticed that the fluid only fills up the little centre circle part in the reservoir if you know what i mean and im not sure whether it should fill up the part around it aswell ?
any answers will be appreciated
andrewmctiernan
08-09-2015 03:05 PM
