Rs turbo rear brake power??
01-06-2013, 08:28 PM
I've changed my brake shoes.. But when using the foot brake..i can still turn The wheel a bit... Should i be able to?
03-06-2013, 06:13 AM
No one know? Its due for a re test and could do with some advice on why the rear drums are pants...
03-06-2013, 07:40 PM
Did you adjust the rear shoes before you refitted the drums
03-06-2013, 08:06 PM
Yeah.. Adjusted the hand brake, adjusted the shoes so the wheel can just do one rotation when spun... They go tight.. But i can just about turn the wheel by hand..
03-06-2013, 08:11 PM
The annoying ginger guy
Use a die grinder and cut diagonal slots inside the drum like a groved disc, are the rear cylinders working ok
04-06-2013, 08:34 PM
Yeah cylinders push out when i remove the drum..but are crap when i put the drum on..
04-06-2013, 08:58 PM
Is the pedal spongy or firm
04-06-2013, 10:01 PM
Engine Machinist
rear load valve? its going to be light on the braking when its jacked up if its working properly.
05-06-2013, 10:06 PM
I think it was the load valve..i jacked it up and stuck some blocks under the suspension arm and lowered the jack.. They seem to work now.. Cheers folks
original
30-01-2022 08:20 PM
jason_nike
18-08-2019 10:53 AM
track.focus'd
12-08-2015 05:53 PM
Bosch
04-08-2015 05:14 PM
