Fiesta st gearbox or helicoil?
21-05-2013, 10:11 PM
My fiesta st 2006 has stuck in 3rd gear, I been told I need a new gearbox but a mate says I only need a new helicoil to fix damaged threads, any advice on what to do?
21-05-2013, 11:34 PM
Engine Machinist
Your question is a bit vague, Is the damaged thread part of the gear selection mechanism? Any pictures of the damaged thread?
22-05-2013, 09:58 AM
Yes it is part of the gear selection mechanism, I dont have any pics at present, it is still in the garage, is that any help?
23-05-2013, 06:40 PM
Well if its just a mounting thread inside then yea just helicoil the damage or fit a threaded insert if enough material!!
Assuming nothing else is damaged inside!!
23-05-2013, 07:18 PM
Fixing Fords
Nothing wrong with a helicoil mate, they are common in alloy components in high strength applications from new.
23-05-2013, 10:48 PM
Engine Machinist
The helicoil is the cheap option, worth a go before you spend a fortune on a new gearbox
TPM961
15-01-2018 10:50 AM
mk1turboestate
02-12-2015 08:31 PM
Andypandy260
23-09-2015 10:28 PM
fordfiestamk3
11-09-2015 12:52 PM
gingeRS
04-09-2015 06:29 PM
