Focus st170
17-05-2013, 11:36 AM
Focus st170
Hi I've got an st170 this morning when I was driving home I started to lose power,then when I tried to go up a hill I have zero power. Sounds like it is misfiring on tick over and when I tried to set off it was juking and didn't have much power. Can anyone come up with any ideas what it could be whats causing the problem?
17-07-2013, 12:22 PM
did you find out the problem because my car is doing the same and it driving me crazy. any help would by very kind thanks
17-07-2013, 12:30 PM
Could be, plugs, leads coil pack is the things I check first the plugs was knackered on my st170 and I had the same problem
17-07-2013, 03:58 PM
well its had new plugs, leads, coil pack, fuel filter. and its still doing it.
17-07-2013, 04:17 PM
Not Crazy, just Unwell
Quote:
Originally Posted by
Jay Fry
Fuel pressure regulator??
17-07-2013, 05:23 PM
Have heard by a mate that injectors are a common fault in the focus model, that's what I was told
17-07-2013, 05:28 PM
justin st13
That was my second thought. It's either not fuelling right or not sparking right. And the laters done so fuelling side of things
17-07-2013, 07:37 PM
you cant fix stupid
they are notorious for fuel pumps going wrong. have a garage check the pressure at the rail.
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
Steve Escos
Ford Focus ST Parts for Sale
02-09-2019 11:39 PM
Tank Mike
18-05-2016 09:38 PM
pie-face
15-09-2015 10:43 AM
Tank Mike
10-09-2015 07:56 AM
