Cosworth engine loom
Hi can anyone help me with with a cosworth engine loom problem. A few years back I had Engine Advantages modify my P8 ecu to run 8 injectors and anti lag. They also supplied with an engine bay loom. I've finally connected them together but when I switch the ignition on the ecu relay buzzes and the fuel pump relay doesn't power the fuel pump. After doing some wiring checks I've found that the wire from the ecu relay pin 85 goes to pin 24 of the ecu plug. I have a cosworth wiring diagram and it shows it should go to pin of the ecu plug. Can anyone help with right connection please.
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
muz
16-08-2015 12:57 PM
